Joined: 04/10/2013 Posts: 2 Points: 6 Location: England
Have I made a mistake ? as I have no gun deck inside the AFT LOWER gun port. Can any one help.
Hi, Don't worry this is correct. It will be a closed port and therefore requires no deck and dummy gun support
Hi Andy. Thanks for your help, I was going by the large picture of Sovereign which shows a cannon in that port.
Hi Doggy, No problem. My understanding is that those pictures are not of the model we are building, but are of a model built by a someone from scratch, upon which this model may be based. So there may be a number of differences.
Joined: 03/01/2014 Posts: 1 Points: 3 Location: Malta
 [/URL] Hi Just to confrim. Is this gunport you are refering to? Ivan
Hi Ivan, am well into this model now and the gun port you are referring to is to be a closed port.... Good luck with your build.... Regards Alan
