This latest 1/32 Revell release consists of 435 parts. It includes full engine detail together with a large selection of stores. The leading edge slats can be assembled in the open position and the detailed engine has its own display trolley. Markings are included for two aircraft.
Kit details:
Two-seat Cockpit with Instrument Panel Eurofighter with a detailed EJ200 engine Finely structured surfaces with recessed panel joints Detailed 11 Piece Ejection Seats Detailed Cockpit Moveable Canard Wings Detailed Air Intakes Two configurations for the Thrust Jets with individual Jet-pipes Detailed Large Air Brake (extended or retracted) Detailed Undercarriage with finely detailed retraction struts Detailed Undercarriage Bay Separate Ailerons and Flaps Separate Rudder Detailed ECM Pods Air Refuelling Probe extended or retracted Two External Tanks Pylons 4 METEOR Guided Missiles 4 AMRAAM Guided Missiles 2 Sidewinder Guided Missiles 2 IRIS-T Guided Missiles 2 ASRAAM Guided Missiles for the RAF Version 2 Laser Guided Bombs a choice of two TAURUS Guided Weapons 2 STORM SHADOW Guided Weapons for the RAF Version Super-detailed EJ200 Engine Detailed Spacing Rings and Heat Shields Servicing Rig for the EJ engine with detailed support profiles and suspension links Super Decal Set for the Bundesluftwaffe and RAF versions
