I came second in a competition with this build.
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Excellant build, love the stowage on these things HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
I have this one from Trumpeter but not got around to making it yet.. Very nice build Nem
Warthog wrote:I have this one from Trumpeter but not got around to making it yet.. Very nice build Nem This is the very same kit!!
Nemesis wrote:Warthog wrote:I have this one from Trumpeter but not got around to making it yet.. Very nice build Nem This is the very same kit!! Look forward to building this one then! Not even opened the box but i know some of there cheaper kits have a lot of flash (Challenger MBT springs to mind)so what is the finish like?
Hi Nemesis First class job,your work is so detailed you are setting such a high standard great stuff. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Warthog wrote:Nemesis wrote:Warthog wrote:I have this one from Trumpeter but not got around to making it yet.. Very nice build Nem This is the very same kit!! Look forward to building this one then! Not even opened the box but i know some of there cheaper kits have a lot of flash (Challenger MBT springs to mind)so what is the finish like? This is one of their later kits, so its got a good finish. I did use a metal barrel though, I was not impressed with the detail on the kit one.
some loverly weathering, looks like you have used chalks? very nice in deed. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
jase wrote:some loverly weathering, looks like you have used chalks? very nice in deed. Close jase, ground up pastels to get the sand effect. Used the same on the Churchill.
Nemesis, have to say stunning work, beautifully put together... Regards Alan
