7 Piece Wood Carving set Options
#1 Posted : 24 July 2012 20:17:56
BigGrin Hi All
iv been using this set for a while now and thought id mention them here,alot of the more experienced builders will probably be already using them or somthing like them so this is a recomendation to the less experienced on the forum.Its a set of 6 blades 1 square chisel,2 skew chisel 4mm and 6mm,1 V chisel and 2 bent gouges 3mm and 6mm[half moon] plus a sharpening stone.They sit comfortably in the hand and are very good for reaching those hard to get at/reach places,one word of warning these blades are very sharp so use with caution as its easy to take off more wood than you wanted or even your skin.But with practice i find them a very usefull tool
This page was generated in 0.087 seconds.
