Spray Booth Options
#1 Posted : 15 May 2012 21:58:16
BigGrin Hi All
just got this off Amazon for £72 +postage,i have seen the same one at £90 odd elsewhere, its not massive at 48cm by 42cm by 36cm but should be good for most small aplications apart from ships hullsBlink
#2 Posted : 23 May 2012 16:38:46
BigGrin Hi all
a few pics of the above booth as recieved,it folds away to a compact sized box and has a neat plug storage also you can fit two together [or three]to make a wider spray booth
#3 Posted : 23 May 2012 18:42:57
That looks pretty cool Andy Cool Let us know how you get on with it. I.E fume extraction etc
Spencer
#4 Posted : 23 May 2012 18:55:36
BigGrin Hi Spencer
The large blue bit at the back is the filter it has a computor type fan on the rear. You can buy an extension peice to send fumes ect out of a window or door.il post more when iv used it and thanks for the reply
#5 Posted : 26 May 2012 13:48:48
BigGrin Hi Spencer
Used this a couple of times now and it works a treat,Its very quiet and fume extraction is good you can see the overspray being drawn to the filter as you use it,i have only used water based paints so far but im sure it will work fine with solvent based paint too.All in all im happy with the results
PS
I also made up a cheap table to put it on,buy a wallpaper pasteing table[around £8],unscrew the hinge then remove the legs from the part you wont be using then transfere the legs to the hinge end of the tableCool
