Help fitting parts Options
Barnacle-Bill
#1 Posted : 21 April 2012 17:43:51
Rank: Newbie
Could someone give me some help with part No.70Confused , how exactly do these parts fit, I'm not having much success getting the parts located, so any help will be appreciatedBigGrin
#2 Posted : 21 April 2012 21:38:03
Hi Bill,
What exactly are you struggling with., For issue 70 the construction task is similar to the construction of the main topgallant mast completed in issue 64, where the shaping techniques are covered in issue 63.
RussG
#3 Posted : 26 April 2012 10:06:57
Can you pst a picture to give us a clue at what stage you are at, part 70!! Thanks
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
willie
#4 Posted : 26 April 2012 11:14:54
part 70 is the trim below the cabin 3 parts per side if you place one below the cabin with out glueing it glue the second part to this part and the thired to the second part remove from model for shaping may need to shape for for a good fit to the hull as you begin ps the curved side is the out side
#5 Posted : 03 May 2012 00:23:49
I found shaping after glued in place worked better
