 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 05/05/2011 Posts: 66 Points: 138 Location: Manchester
Looks a good first effort though. I think i would prefer a glass top as well so you can look down on it. I appreciate you wanted a solid top so you could put the lights in, but I think you have had to make the case quite high to compensate for not being able to look down. I like the finish on the base. What have you used for that.
 Rank: Pro  Groups: Registered
Joined: 01/07/2011 Posts: 383 Points: 1,194 Location: Birmingham
If you do a glass top, you could run the lights around the rim on top. That would look wicked! Gives me ideas for mine!
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,187 Points: 15,710 Location: ipswich
I saw a similar display case with an Amalgam 1/8 Ferrari in it in the Ferrari shop in Regent street, London - it had a slightly tilted mirror as a 'back wall' allowing for a nice downward view as well. Good work. Roy.
Joined: 05/07/2011 Posts: 126 Points: 354 Location: Withernsea East Yorkshire
Bit big is it not Skiddy? only my thoughts thats all as you say a glass one would be better so.......you best get on the case and make it haha see what i did there? MeffMan
Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
 Cracking Job there mate! Very good indeed!!! Chris
