Joined: 03/03/2018 Posts: 26 Points: 81 Location: Peoria, IL
Howdy, As I see I've even outrun the official build diary (nothing happens after Memorial Day?) I'm a little stuck with getting the fuselage top to fit correctly over the two small pins sticking up. Seems like every time I just set it down and can see the pins, as soon as I lower the piece a little farther the pins move to the side and won't fit up through the holes. Does anyone know the trick to getting this done? Thanks! Jim/Flyteach
Hi Jim Not at issue 77 yet. I assume you are talking about the two pins for R2 to operate. Having looked at the instructions and images, I can only presume that the holes are stopping the pins going through. Check there is not anything blocking the pin passage, such as moulded ridge that was left over in production. Maybe get something of the pin size and push it through the holes to clear it. Sorry I can’t help any more. Mark Regards Markwarren (Mark) Admin
Hi Mark, Actually, I got it, but thanks for the reply. What I had to do was push a pin (used my awl which is about 3 inches long) in the whole just to the side of the two pin holes and kept moving the pin base around until they fit. It was just fidly. Jim
