Charging the battery-Replacement Battery Options
GilShapley
#1 Posted : 20 June 2020 08:44:28
How long should it take to fully charge the battery. Cant seem to find any info on this in the instructions. My T-72 will run and all the controls seem to work as they should but the run time seems very short.
Found it in the Guide States less than an hour Blushing Blushing
Confused Confused Confused Confused Confused Confused
Still need an answer to my second question
I always think it is a good idea to have a second battery pack. I have been looking online and would like some info from you experts. The spec of the battery supplied is 7.2 Volts and current strength 2000 mA. If I get a battery with higher mA will this cause problems??
Current Build:-
This page was generated in 0.103 seconds.
