Problem with Left and right inside foot covers not fitting Options
OzPalin
#1 Posted : 29 December 2019 07:42:17
Rank: Newbie
Hi peeps
I am having, what looks like a design issue with the inside left and right foot covers, neither fit properly to the R2 (pic Attached when i work out how lol)
OzPalin
20191229_155645 1.jpg (2,040kb) downloaded 48 time(s).
R2D2Nut
#2 Posted : 29 December 2019 08:04:08
If I remember right, I had a problem with the cable routing where it came out of the leg and keeping the cover from going on right. It's hard to say for sure with your issue. If you can, remove the cover and snap another photo without it so we can get a little better view.
Please be assured that it does go together right. Way too many R2's have been assembled and working for it to be a design issue.
Fred
OzPalin wrote:
Hi peeps
OzPalin
#3 Posted : 29 December 2019 10:21:11
OzPalin wrote:
Hi peeps
OzPalin
This has come up before, it is caused by the inner wheel support plate fitted on the wrong side or incorrectly. This then causes the foot panels to not align. Double check your assembly against the instructions or the official build.
Hope you get it sorted.BigGrinThumpUp
R2D2Nut
#4 Posted : 30 December 2019 01:46:45
I knew I had done something along the same lines and had to disassemble it and put it back together to figure it out.
Thanks Mark
Markwarren wrote:
OzPalin wrote:
Hi peeps
OzPalin
