Joined: 31/08/2019 Posts: 2 Points: 6 Location: London
Hi, Ive just added the base to the chassis and wired up all of the lights. I added the batteries as per instructions and the sound keep generating the engine noise, pressing the accelerator pedal does not make any difference. also while the engine sound is generating the lights dim. Does anyone have any ideas on what it might be?
Repudiator wrote:Hi, Ive just added the base to the chassis and wired up all of the lights. I added the batteries as per instructions and the sound keep generating the engine noise, pressing the accelerator pedal does not make any difference. also while the engine sound is generating the lights dim. Does anyone have any ideas on what it might be? It sounds (hihihihi) like you might need a new gas pedal. The dimming lights might be old batteries. Were they fresh? Give CS a ring for the new part.
Hi Mark,
I'm sure the batteries were fresh, that said I've ordered some more and they should be here tomorrow to test (Amazon Prime has it's uses). I'll test again before contacting CS use in case.
Cheers
