 Nice project ,if your using it as a new man cave for modeling I would recommend you insulate the walls and add an inner layer of wall. This will benefit you all year round and be very useful for keeping a constant temperature if your going to be painting in there too. Also consider adding double glazing, power and heating for the winter months. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I was thinking of adding plaster board walls and insulation not sure it's well enough built to worry about double glazing. Ken's the name modeling's the game.
that look like a ton of fun Ken .Although with your history of modifying your models I am surprised you havent added a turret or clock tower to the shed Carl
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,196 Points: 15,737 Location: ipswich
A thought Ken... Did you wood-treat the outside of the panels up against the fence?
Factory shed treatment is notoriously naff and you don't want the bottoms of your panels starting to go soggy after a few years.
Also, I wouldn't use plasterboard in a shed. It will absorb moisture from the air and start to swell at the edges. A cheap carpet on the floor makes a big difference to keeping it warmer too.
Have fun.
Roy.
Thanks for the info Roy. Ken's the name modeling's the game.
