Joined: 11/01/2019 Posts: 2 Points: 6 Location: Idaho, USA
Modelling Putty - Pack 5 directs to cover the hull in MODELLING PUTTY. What type do you recommend and where can it be purchased. Thanks
Hi you can use any good wood filler from your local model shop or go to your local hardware store and use any good brand of wood filler they have or you could use car filler/bondo to do the job the choice is yours. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
