Question on hull shell Options
millenniummax123
#1 Posted : 20 March 2019 06:19:13
Hello,
Is there an issue number where they tell you to attach the hull shell to the frame? Not sure if we should be keeping track of what shell comes from what issue? I have just been collecting them and putting them in a bag. Will this be ok? Also, my metal frame has a slight curve to it when I lay it flat. Is this how it normally is?
Thanks,
#2 Posted : 20 March 2019 10:27:10
You will make the frame up, bottom one first before it will instructed you to add the panels. The panels will be straight forward to fit and the instructions are quite clear.
The pieces of frame do have a curve and once you start to connect then together you will be given supports to hold them in place to stop them from bending and warping.
This page was generated in 0.082 seconds.
