 Rank: Amateur Level 1  Groups: Registered
Received the ship kit but missing all the mast and rigging plans. Are they sent separately? It seems the build instructions are a might thin compared to the 3 other ships I have done. Not for the faint of heart if no previous experience.
Just sent you a PM. Cheers Mark Regards Markwarren (Mark) Admin
It has been 4 m months now, still no mast or rigging plans. What is the issue with this company. Does anyone else having this problem?
I don`t know for sure if this is what you need but if you follow the link below about half way down the page is a tab "The Build". Click that tab and the instructions for each pack appear as downloads. If you scroll down that list at the bottom there are two downloads titled "HMS Surprise Mast Plan 1" and HMS Surprise Mast Plan 2" Really hope this helps. https://www.model-space....d-the-hms-surprise.html
Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
I have built 3 models ( Victory, Soleil and Constitution). All provide printed plans for the masts (although some required downloading the build instructions) since you need to measure off them and you can not print the large sheets. The kit came with the assemble instructions. The rigging is in the line and I can print these off the web since they do not need to be to scale but building the 3 masts and bowsprit (which I do not see in the link) is extremely difficult since nothing to measure off from, especially the tapering needs for the yards.
You should receive the plans in pack 12 when your ready to make them. If you not got them contact C/S. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
I have called costemer service several times over the last several months, still nothing.
