 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello there would anyone know how to remove glue residue after removing planks for formers or ribs, reason why sadly I had to remove all planks from model something wasn't right in the bow area and gallery support thank you Ronald
You could try soaking in warm water, that usually works. I tend to use a course grained glass paper, 120 or even 100 and run lightly since you don't want to remove any wood.
ok thanks John you right about sanding lightly as far as the warm water part do you mean using a towel dampened in warm water Ronald
Depends what the part are. Can you soak them separately?
