Looks like i will be about to start it up next month. What fuel should i use for the first tank? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nothing less or more than 15% for the first 3-4 tanks and no more than 20% thereafter if you want engine longevity, the make does not matter. Also get a bottle of afterrun oil.
Always empty the tank and fuel lines after the days running and use the afterun to protect the internals. Remember that nitro fuel is hygroscopic (absorbs moisture), thus can induce corrosion if you don't use afterun oil.
I can't seem to find any 15%. Can only find 16%. Is that ok? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
