dust problem Options
benny
#1 Posted : 08 May 2011 12:11:39
hi all i am rigging my cannons wen it dawned on me that this deck with the finished cannons and gratings will be finished wen we plank the next deck..now the finished deck will be covered in dust from sanding the decks above does anyone else think this maybe a problem cause we wont be able to get a hoover in there to clean it or am i worrying for nothing
cheers benny
IAN
#2 Posted : 08 May 2011 12:41:27
Hi Benny...
i was looking at this problem the other day and come up with the idea of, air canisters, you see them in camera shops for cleaning camera lens.
regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
benny
#3 Posted : 08 May 2011 12:49:59
IAN wrote:
Hi Benny...
regards,
Ian
hi ian you mean blow the dust out,i do have a hvlp paint sprayer with compressor i suppose that will do it,just have to make sure everything secure
cheers benny
#4 Posted : 08 May 2011 12:57:36
If you use a combination of a puffer brush and a vacuum cleaner you should be ok. the danger of just blowing air is you force it into corners etc especially under pressure. puffer brushes used for camera cleaning have less pressure but will do the job get a big one like the rocket they are not expensive.
thomasmoult
#5 Posted : 08 May 2011 13:03:03
I found that a good blow and tilting the ship upside down got all of the debris out. I also made a template the exact size of the quarterdeck opening that was taped to the beams (which will later be cut out) helped when sanding the deck. I think once these beams are cut away I'll come up with something that I can stick on the underside to prevent any further debris going in.
I found that after having cut bits of bulwark away and trimming of the openings etc, the deck around the cannons looked somewhat how it must have done after a battle.
Tom
Glen
#6 Posted : 09 May 2011 13:47:18
Hi Benny,
I got around the problem of dust from sanding, i bought a small vaccum cleaner made for computers.
It's 250mm long and has a nozzle of 14mm by 5mm and it runs on a couple of batteries, it's quite powerful.
Hope this is of use to you.
Glen
Roger the Cabin Boy
