 Rank: Beginner Level 1  Groups: Registered
Joined: 19/02/2011 Posts: 9 Points: 27 Location: isle of wight
ok ive not been able to get alot done on my model since febuary due to real life getting in the way and moving house. But ive finally managed to get the planking all but finished on 1 side and down to he last 10 rows on the other.I have to admit i found it tricky to get them planks to bend at times without hearing the dreaded snap. But im feeling brave enough to post some pics and open myself up to community opinions http://imageshack.us/pho...ages/828/dscf0044q.jpg/
http://imageshack.us/pho...ages/156/dscf0045l.jpg/
http://imageshack.us/pho...ages/713/dscf0047w.jpg/
http://imageshack.us/pho...ages/594/dscf0048j.jpg/
Im hopeing i have done enough to get rid of the bulge i had at the rear due to not sanding enough as pointed out by tomick, hopefully its enough Demeck
looks really good mate “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Coming on well, though it might be an idea to draw a centre line down the bow so you keep track of the centreline for when it comes to adding the curved stem/keel
Joined: 06/05/2010 Posts: 233 Points: 708 Location: Leigh on Sea
Ummmmm good thinking T Man guess that explains why Iam a number 9 H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
Thats strange yesterday I was a number 9 now Iam a number 8 ...it's all very strange ..good job I don't give a fig if Iam a number 8 or a deckboy...but Iam a 67 later this month..hello NURSE H.M.S Victory H.M.S Victory X Section H.M.S Surprise under the bench D-51
It's shaping up nicely shipmate, keep the pics coming. A small tip, using some 'bubble-wrap' between the stand and the hull would stop the likelihood of your good work on the hull becoming accidently marked or scratched Happy building Daffy09
ah good idea mr t will do. and yep taffy your right, will line the stand with some protective cover used for lineing the rim of a bicycle wheel to protect the inertube from the welding points on the spokes. got some grt stuff from the repair on me daughters bike  nice and fluffy. Demeck
