The question is, how many are there?
I went through all the packs pulling out the cannons so I could build them all in one go. Altogether I found 20 to construct.
I completed the upper gun deck building and rigging out 10 as per the instructions so I have another 10 ready. Now that I am working on the quarterdeck it appears that only another 4 are required, the other 8 on that deck will be dummy guns under the poop deck.
Am I missing something here or have I done something badly wrong?
Some may be used for the cutaway decks but not sure.
Hi John,
You haven't done anything wrong at all.
19 Cannons provided where you need 10 for the upper gun deck, 6 for the quarterdeck and a further 2 free standing cannons (without rigging) that will sit on the foredeck. The rest are dummy guns with the exception of the 2 carronades.
Hope this helps.
Thanks Al and Alan. Looks like I have a couple spare since I am not doing the cut out.
Joined: 26/01/2018 Posts: 68 Points: 210 Location: South Africa
Hi I know this is an old post but I have been going through all my packets looking for cannon so I can build them all at once as well and I have found 19 = 1 cannonade not sure if there should be more than one of those If my ship's going down,I'm bloody well getting off
Hi Trevor
The second Carronade comes with issue 95 along with the instructions for making and fitting.
If this is missing you will need to contact customers services and they should send you a replacement.
