 Rank: Pro Groups: Registered
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Hi all you shipbuilders,
A couple of questions which I have which I am sure you can answer for me.
1. Building up ribs, the preference/recommended method seems to be using card and super glue which included soaking the card with super glue. Is there any reason why wooden planks can't be used particularly when I have to build up rib 16 by approx 1 mm?
2. When planking what is the best order of preparing the planks. Bend, taper and then chamfer?
Hi there Atholm, I used spare planking to build up the ribs mate... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hello Atholm,
The method that I use is first to cut the plank to required length, next shaping the plank, that is tapering, after which I then chamfer the edge and finally, work on the bend. There may be other ways but this is the my personal preference through the experience of this build - this being my first attempt at anything like this. Through experience I found that bending the plank first made the other 2 operations that much more difficult and chamferring before tapering negated the effort of the chamferring where the tapering had been done.
Hope this helps and happy building Daffy09
"Good judgement comes from experience. Unfortunately, the experience usually comes from bad judgement"
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Hi all. I absolutely agree with Daffy.  Wet and bent planks are very difficult to work on. If they should need a little tweak then this can be done when fitting after bending, but doing all the shaping at this stage is not advisable. Laury
Thanks Maties, must appreciated
Athol
