 Rank: Pro Groups: Registered
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
I decided to try the drill supplied with the fee took kit. Is there some thing wrong with mine or is it just poor quality, the chuck does not run true and if I use it on a thin bit I will bend or break the bit. The end of a 1mm bit scribes a circle of 3 to 4mm.
Has anyone else had a similar problem?
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
I have also broken drill bits and it fell apart, I took it apart to see if I could repair it and it is badly made. Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
I can't use my drill either. Real shoddy I bought an old one from a second hand tool dealer, much better quality and it works as per the instructions
Been using mine by twisting it Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Joined: 10/06/2010 Posts: 20 Points: 63 Location: ROCHESTER
HI IF YOU LOOK ON E-BAY YOU WILL FIND ARCHIMEDES DRILLS FOR ABOUT FIVER THESE HAVE DRILL CHUCKS THAT TAKE DRILL BITS WITHOUT THE NEED FOR COLLETS, THIS IS WHERE I GOT MINE FROM MUCH BETTER QUALITY.
HI VENICE That is exactly the same as the one i brought and drill set found the bits are brittle if care is not taken, the drill gets better with use 100% happy with mine. i also brought a 150pc min micro drill set for a tenner ,sizes from 0.4mm to 3.2mm,smaller sizes go up in 0.1mm increments and come in tens and the larger in 0.2mm increments been very good set and has spare sizes when i break a bit. sorry cant put on link have not figured out how to do it yet.
These ones you mean: http://cgi.ebay.co.uk/ws...:MEWAX:IT#ht_1489wt_772
Going to buy them as well Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
THATS THEM
I gathered that Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
I got my drill bit set off amazon and got free next day delivery, nice one  , same price about a tenner. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
I shall try looking at Amazon too then Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Thanks for the advise and comments
Unfortunately living in South Africa is a problem with most of the mail order firms and were they do send to RSA and the postage cost makes expensive.
I managed to find a drill use link below which cost me $14.82 which included air delivery. http://www3.towerhobbies...1p?&I=LXLJ02&P=7
