Paints advice Options
Gan_Javi
#1 Posted : 09 January 2011 14:28:20
Hiya,
I have 3 questions for you guys. Would appreciate the advice.
1. What colours, and how much of each, of the paint do you guys think would help?
2. What kind of paint is best to use?
[Like accrylic etc...)
(This is my first wood build, and I have no idea whatsoever when it comes to paints)
3. Where in Cape Town can I find a good hobby shop that sells products for wooden ship builds, and possibly the ships too?
I know of a place called "Clowns hobbies" but haven't been there yet. Any others?
Any help would be appreciated =)
Francois
Quintin
#2 Posted : 09 January 2011 16:32:22
The HMS Victory Paint Set that most online shops sell comprises 14 X 18ml waterbased paints. It is also available on e-bay, I have bought plenty of stuff there, and it usually takes about 2 weeks to arrive.
The sets comprise of:
3 x Dull black
3 x Yellow ochre
1 x Red Ochre
1 x French Blue
1 x Walnut/Wood Brown
1 x Matt White
1 x Olive Green
1 x Gold/Brass
1 x Metal Black
1 x Copper
(all 14ml bottles/tins)
you could also get an etch primer for use on metal components ie oars
If you can not get a set of paint, then go for individual acrylic paints from your local hobby shop. I definitely don't recommend enamels, those are only good for metal and plastic, and even then, I shy away from them, preferring the acrylics. Another plus on the acrylic is they are water based, so mistakes and dirty brushes can be sorted out with tap water before they dry.(Acrylics are a bit more expensive, be prepared to shell out anywhere between 25 and 40 bucks a pop, depending where you go and the size of the bottle.)I am also going for a painted model, and will try find copper sheeting for the hull when I finally get that far.
Hope this helps! Laugh
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
Quintin
#3 Posted : 23 January 2011 07:38:30
Ok, so the durban hobby shops do not stock yellow ochre. After much grumbling, I descovered a good place to look is the art and craft shops. They sell artist's acrylics for 20 bucks for an 80 ml tube. You will need to thin it with water and it takes longer to dry, but again, 20 bucks for an 80 ml tube Love I got mine at the craft shop in the crescent shopping centre, Umhlanga Rocks
Built: Pinta
Endeavour
