 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 16/02/2015 Posts: 76 Points: 80 Location: USA Phoenix
I need some help on stage 109 step 4. From the attached photo you can see where I laced the 3X3 on the edge. When I do this, the engine cover does not sit properly over the engine compartment. It would seem that i put that short stick 3X3 in the wrong place but it looks like it should be there according to the instruction picture in step 4. Can you help
Hi You have glued the piece of 3x3 on top of the frame where it supposed to be on the side level with the top of the frame. I have also removed your other posts regarding your problem as I see no need to ask the same question 3 times Regards Spencer
