Joined: 21/07/2015 Posts: 41 Points: 123 Location: USA
I know that the sublight engines and cocpit are lit with the kit as well as the headlights. Is there anywhere else on the kit that is going to be lit? I'm planning on building my Falcon completely from the kit and not doing any aftermarket mods (although I did create a bunk wall detail out of sheet styrene and little greeblies I made with Apoxie sculpt) and then doing my own painting and weathering so I'm trying to figure out which hull plates I need to light block?
Off the top of my head we have:
the ramp forward mandibles both gun windows
and as you already mentioned:
engines cockpit
