preparing the Launch for painting Options
wolfskin
#1 Posted : 22 December 2015 09:44:30
Hi TeamBigGrin
After many hours of fear of turning the Launch to dust. I have managed to plank the launch & seperate it from the Jig now ready for painting .There are a few very small gaps between the planks, shall I just smear the outside with PVA and then paint or should I use wood filler ?The gaps are all well under .5 mm .Also what sort of paint would be best ,Acrylicor oil?Any advice would be much appreciatedBigGrin BigGrin Cheeers Wolfskin NZ
#2 Posted : 22 December 2015 09:59:58
BigGrin Hi wolfskin. I used PVA and sanded so the dust went in to the joints but the gaps have to be very small for this to work. If they are to big the best bet is to use filler and then sand Cool . For the painting I used Acrylic paint
Hope this helps rgd Martyn
wolfskin
#3 Posted : 23 December 2015 06:44:16
Thanks Martyn think I might apply a little filler in a few places.I don't want a visit from Mr Murphy at this stage .
Cheers
WolfskinBigGrin
