Joined: 03/08/2010 Posts: 39 Points: 117 Location: Grantham
Hi all, I'm starting the decals for these wings. The magazine states to put them on the inside of the wings, but looking at the professional pics of the actual race car, they look to be in the outside, which matches the other decals. I'm a little confused!  can someone confirm if I'm correct? Many thanks, Steve
Hi Steve Can you supply a link to the "professional" picture that shows the decal to the one your asking about please so Ali can provide you with the right information Regards Spencer
 Rank: Pro Groups: Registered
Joined: 25/09/2013 Posts: 112 Points: 308 Location: UK
Lakes74 wrote:Hi all, I'm starting the decals for these wings. The magazine states to put them on the inside of the wings, but looking at the professional pics of the actual race car, they look to be in the outside, which matches the other decals. I'm a little confused!  can someone confirm if I'm correct? Many thanks, Steve The magazine is quite correct, the thick black line decals go on the inside. And if you turn forward to page 22, Stage 8, you will see that there are different decals which go on the outside of the upper border wings. (Which presumably are the ones in your photograph.)
Great, thank you mattsr! Should have read through a little more ;-)
