on simple question.
what the heck is a windlass for?
it carries the anchor underneath the launch willz attached the following image(s):
Joined: 23/03/2010 Posts: 205 Points: 598 Location: West Midlands
I googled and came up with this:- The windlass is a means of converting rotary motion to linear motion, usually with some mechanical advantage. Essentially a class 1 lever, the effort is applied to the handle of the crank, the fulcrum is the centre of the drum, and the load is applied to the rope. The mechanical advantage is approximately the length of the crank divided by the diameter of the drum. Since starting this build I learn something new almost daily. Happy building CMB[
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
To me a windlass is a nautical term for a simple rope and block lifting devise (Simple crane)
to me, the word windlass is mean't to mean windless,it's use is to move the ship when there is no wind,drop the anchor out at sea,and wind like crazy to move the ship. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Rank: Beginner Level 3  Groups: Registered
Joined: 12/06/2010 Posts: 20 Points: 60 Location: Wales
A windlass is a smaller version of a capstan, primarily used in smaller vessels.
quote period pieces #36 "a horizontal winch for anchor work similar in use to a capstan"
capstan~ a vertically mounted rotating device for raising the anchor
