 Rank: Beginner Level 1 Groups: Registered
im having a spot of bother with fitting the lexan body. I followed the instructions very carefully but cant understand how the side barge boards interact with the two notches under each side pod of the lexan body. If someone can post a close up photo of how it should look that would be great.
Joined: 05/04/2013 Posts: 540 Points: 1,630 Location: England
This is the only photo I can find for the moment, so not sure if will help you or not. The body should just sit over the outer edge of the board. Full size image.Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
