 Rank: Pro  Groups: Registered
Joined: 24/09/2013 Posts: 180 Points: 550 Location: East Sussex
Hi all, made a mistake and got glue on the bodywork under the aigo logo, how can I remove it? Pleassse help :(
Hi Mark Unfortunately you will have to get another issue from the DeaGostini shop unless you want to respray the whole body work. http://shop.deagostini.c...build-your-own-mclaren/
regards Spencer
I read this online,
does this look like it could harm the silver paint?
Warm, Soapy Water Mix a few drops of mild soap, such as dishwashing liquid, with water in a large bowl. The mixture should be fairly sudsy. Soak a soft, clean cloth in a sudsy mixture of soap and water, and apply it to the spot where the Super Glue has spilt. Cover the cloth with plastic food wrap, and tape it down so that the moisture does not evaporate. After three or four hours or more, remove the tape, plastic food wrap and wet cloth. Using a dry soft, clean cloth, dab at the spot where the Super Glue is located. Use a blotting motion, and turn the cloth frequently; do not wipe or rub the spot. The softened glue should come up with the cloth. Repeat this procedure if any Super Glue remains until you can remove all traces of it. Wipe the plastic surface dry with a clean cloth.
It might work on unpainted surfaces but doubt it will work on a painted surface. You can but try it, you can always resort to obtaining a replacement.
thanks guys
I want to avoid a replacemnt as I have put loads of effort into the main body with decals and carbon fibre detailing
I will try and let you know
Thanks Mr T,
It has brought into question my modelling skills and I am very nervous about the entex mclaren :(
You should not have any requirement to use Superglue for your Entex build as its a polystyrene kit, a liquid poly is best used but still needs the same care of application.
Once again..
wise words from you Kev!!
I will do some touching up bits tonight, i think i will improve it, and it wont be an issue,
the MP4 23 will be finished in 4 weeks and I cannot wait!!
the end is in sight!!
By the way guys, it's all sorted now, I was able to touch it up and it's unnoticeable
Thanks Spence, Mr T and Kev!
