Kudos to Customer Service Options
mwb
#1 Posted : 04 March 2015 02:22:25
While building the base I came across two cross threaded cap bolts (honest - I didn't cause it) and one of the threaded inserts would not take a cap bolt. Emailed customer service and ten days later the replacement pack was on the door step. Problem solved. Now that's service. Thank you Christina M.
