Electric toothbrush Options
Schnozzle
#1 Posted : 27 February 2015 23:34:20
Rank: Beginner Level 3
Turquoise Medal: Turquoise Medal for model making know-how contribution
Have any of you modified an old electric toothbrush to act as a sander???
I suspect this would be quite easy to achieve, and with replaceable heads, several different heads could be used for differing requirements.
Just a thought!
Eagle
#2 Posted : 27 February 2015 23:41:41
Red Medal: Red Medal
Yes! I have done this; and found it somewhat useful for small areas-the trick is finding a way to make sandpaper pieces interchangeable, maybe velcro would work? For now I use a white glue which is easy to apply and a remove.
Schnozzle
#3 Posted : 27 February 2015 23:51:09
Most electric sanders have velcro sanding pads, so super glueing the hooks to the toothbrush head would allow you to change the sandpaper with ease, after cutting to shape!
