barrel supports - loose Options
alantait
#1 Posted : 03 October 2010 22:12:40
Help, when drilling for the centres of the gun ports, the rear section of the lower deck barrel support has come loose. any advice on how to re attach it already glued and planked the middle deck, i am at a loss on how to get into this section without having to remove a large section of the planking.Crying Crying Crying
current builds
riff-raff
#2 Posted : 03 October 2010 22:26:09
If you can complete at least 2 cut outs then you could use a long thin screw to grab the support through the 2mm hole and then glue from the other cut out. Then repeat the process along the support.
Built:
alantait
#3 Posted : 03 October 2010 22:31:45
thanks riff-raff, panic was setting in, never even contemplated that, just kept thinking start again, remove sides, will it look alright, every emotion was going through my mind, will try this now and let you know.BigGrin
current builds
thomasmoult
#4 Posted : 03 October 2010 22:54:20
The same thing happened to me as well, think I was a little heavy-handed with the drilling!
To fix it I made a hook out of some wire and hooked it through the gun port and grabbed behind the barrel support, then soaked the joints with superglue to hold it, and then finally when the joins were re-attached I PVA'd the joints to hold it firm. Re-painted black again and good as new.
Tom
alantait
#5 Posted : 03 October 2010 23:10:32
thanks for that tom, guess i did not use enough glue in the first place, i have tried what riff raff suggested if this does not work will try your suggestion, anything so as not to have to pull her apart, even the french and spanish couldnt do as much damage at trafalger as i would pulling her apartLaugh
current builds
z8000783
#6 Posted : 04 October 2010 10:56:14
Groups: Unapproved
So you have put the barrels on the lower gun deck? Won't they be completely hidden there? The instructions say they go on the forecastle.
Confused
John
