Joined: 12/07/2014 Posts: 2 Points: 6 Location: Central US
Unfortunately I have had a bad experience with customer service - not about the shipments but about the "free's" that are supposed to come with the 2nd and 4th kits - I worked and called multiple times to get the 1st on (took till after 5th kit) and just called about the one with the 4th kit and I have started to jump through the hoops again to get it - they are saying the same thing as last time about supply chain - no longer trust this company - was going to start 2nt kit but after this will not. JD
jdwigley wrote:Unfortunately I have had a bad experience with customer service - not about the shipments but about the "free's" that are supposed to come with the 2nd and 4th kits - I worked and called multiple times to get the 1st on (took till after 5th kit) and just called about the one with the 4th kit and I have started to jump through the hoops again to get it - they are saying the same thing as last time about supply chain - no longer trust this company - was going to start 2nt kit but after this will not. JD Hi JD, Could you let us know which kit it is you are building, then maybe we can get you a more precise answer as to where the issue of distribution of your required items are. Kind Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Derek - working on the akagi - due kit 6 - J
jdwigley wrote:Derek - working on the akagi - due kit 6 - J Hi JD, As with a lot of company`s, Deag are no different as to be reliant on other company`s for supplies, but give me some time to make some contacts and I`ll see what I can find out for you. Again sorry for your disappointment, but hopefully the issue can be resolved. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
