More Stern and Forward deck details added Tomick attached the following image(s):
Outboard prop shafts fitted, though at this stage the shafts are only temp installed. File Attachment(s): Tomick attached the following image(s):
The Funnel build Tomick attached the following image(s):
The build of the display stand, I added pins into the pillar tops which wil secure the underside of the hull to the display stand. File Attachment(s): Tomick attached the following image(s):
Aft range finder radar and tower build Tomick attached the following image(s):
Assembly of bases for the superstructure, simple enough though filing and filling are needed. Tomick attached the following image(s):
More superstructure Tomick attached the following image(s):
Gun bases added to the superstructure bases Tomick attached the following image(s):
Vent detail added, which are sandwhiched items comprising of a wood base, PE mesh and PE grille. Tomick attached the following image(s):
More gun mounts added Tomick attached the following image(s):
Start of the Tower build, though it won't be secured in place until all its detail has been added, the base plate is supplied later in the series and is needed to raise its height. Tomick attached the following image(s):
Guns, straight forward enough and many of... Tomick attached the following image(s):
Aft gun mount assembly, as before the vents are layered photo-etch brass. Tomick attached the following image(s):
Forward gun mount assembly and photo-etch vents Tomick attached the following image(s):
Guns - lots of them! Tomick attached the following image(s):
