Ratio and aspect Options
Shaky
#1 Posted : 20 April 2014 17:47:50
Just wondering about the scale and definition of detail. How do you decide how much to define the detail on such things as the gun carriages? Do you accent the detail by widening the laser cuts to enhance the detail or do you leave it realistic and fill over them?
Given the scale, how deep should the gaps be between the beams making up the gun carriages?
This has always been an issue with me when building any models even to the point where I sanded all the rivets off a plastic model that I built because the scale said they were not that big!
Any suggestions would be appreciated.
Peter
bb1949
#2 Posted : 21 April 2014 11:03:17
Hi Shaky, Having painted a guzillion warhammer miniatures of the past 20 years or so my first option would be to use either black key lines (paint with a very fine brush (sometimes with only one hair) or use 'inks' over a base coat and then apply top coats using dry brushing, sometimes layering the paint in lighter shades to create more depth. If you were to 'sand back the flat surfaces as you suggest then you could use the above method to achieve some good effects. I will do some samples and add them to your screen to illustrate this. These techniques will come into their own when you start painting crew members and there are some tips that will really add realism such as using light traces of dilute turquoise under the eyes lids.
