Launch Rope Options
jonny7england
#1 Posted : 01 July 2010 16:36:01
My questions are about the rope in the launch, I can see that it needs to lie in a coil on the floorboards of the launch, but has anybody tried to build the coil? If so, how did you keep it in a neat coil, i.e using glue, if so which glue, and is your coil of rope aged, or soiled in order to make it look realistic? If so what was the process you used, and of course lastly...did you place your coil into the bottom of your launch before or after attaching the thwarts?
#2 Posted : 01 July 2010 17:42:11
The method is described in issue 14 or take a look at my build for 14.
jonny7england
#3 Posted : 01 July 2010 20:00:22
Much obliged lads, simple once you know how, nightmare into a piece of cake,,,thanks again ThumpUp
Zeptrader
#4 Posted : 01 July 2010 20:38:33
..and here is another method from MSW
http://modelshipworld.co...mp;highlight=rope+coils
easy, simple, cheap and clean, read the post for more picture.
This page was generated in 0.473 seconds.
