The Magna-Board Options
#1 Posted : 05 November 2013 23:13:57
#2 Posted : 06 November 2013 00:06:29
Tomick wrote:
Hi Mr T,Drool
As you say no explanation needed.
Cracking idea, only shame is we have to import it.
Still looks to be a seriously good bit of kit though Cool
Thanks for the link.
#3 Posted : 06 November 2013 08:18:07
I recon you could make one easily enough.
#4 Posted : 06 November 2013 09:05:33
Small magnets are readily available, all you would need is a steel/magnetic board
Dontshootme
#5 Posted : 06 November 2013 09:09:03
As Jase says,easily copied.Although the items below were bought for displaying plans without covering them in pinholes etc it could easily be used as a build board,admittedly my magnetic board is BIG there are other sizes available.
http://www.ebay.co.uk/it...rksid=p3984.m1439.l2649
http://www.ebay.co.uk/it...&hash=item43b04ca025
#6 Posted : 06 November 2013 10:23:55
#7 Posted : 06 November 2013 10:27:57
It needs to be galvanized steel to prevent rust. It would certainly take the edge off a blade, though the board is not inded to be a cutting board but an assembly surface.
#8 Posted : 06 November 2013 10:31:05
Tomick wrote:
It needs to be galvanized steel to prevent rust. It would certainly take the edge off a blade, though the board is not inded to be a cutting board but an assemly surface.
Thats what I thought, with the aircraft builds your not cutting against the plan too much anyway, just cutting off ends to size etc so should be fine.
#9 Posted : 06 November 2013 10:33:11
Great Planes did an even better version, which incorporated magnetic clamps, but I don't think its available anymore..
http://www.flyhobbies.co...nesmagicmagnetboard.htm
