Guns ?! Options
viperek
#1 Posted : 30 June 2010 18:59:40
Rank: Amateur level 2
Does anyone know if we are going to have to make all 104 guns ? Are even going to receive them or do we have to buy our own guns?
Ta :)
budgie
#2 Posted : 30 June 2010 19:05:29
BigGrin apparently there are 24 canons like in issue 1 & 2 carronades
believe they are all for the upper deck so will be on show
BigGrin the rest of the canons will be on lower decks & u will only be able to see the pointy out bits at the gunports
viperek
#3 Posted : 30 June 2010 19:08:31
Hmm.. If You look at this picture, the guns are there
comic123
#4 Posted : 30 June 2010 19:17:55
If I am not mistaken the lower deck guns are just the tips of the barrels fitted into a recess in the gun port
viperek
#5 Posted : 30 June 2010 19:21:03
ok i do agree but as i said if You look closley on the picture where the bit of planking was cut out the guns look like they are all made of brass and they are complete.. any ideas ?
budgie
#6 Posted : 30 June 2010 19:28:56
BigGrin im not counting how many gunports there are on the model to find out how many canons we will rx + the 24 for upper deckBigGrin
think this has been discussed before a while back so u could use the search engine to satisfy ure curiosity
imagine the canon for lower decks will sit on a lump of wood kept pretty basic as u will only see the barrels
viperek
#7 Posted : 30 June 2010 19:30:44
very true, i ll do some research on that, might even contact CS. Will let You know in the end.
Tiswas
#8 Posted : 30 June 2010 21:19:28
24 Cannons, option to have cutout section of gun deck showing some cannons and crew. Remainder on show on upper deck. The rest are just the muzzles of the cannon poking through the gun ports.
TIS
This page was generated in 0.089 seconds.
