Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
A really stunning build and loads of great detail. Keep up the great work.
Foz
John What a stunning build. Your paintwork is excellent. Thanks for sharing and best wishes for the rest of your build. Kind regards Tony Happy Modelling
Joined: 02/04/2013 Posts: 174 Points: 534 Location: Bethlehem PA, USA
 Here's an updated pic with the masts installed. (Just crappy cell phone pics). They are just about perfectly straight. It was a lot to get them that way, but if you don't start out good, it won't end up good. Since this pic I installed the blocks on the fore topmast and permanently installed that. I'll post some more pictures once I get the shrouds rolling. The "reversed" backstays you see in the picture are actually steel 3/64" aircraft cables that I used as power lines for the LED's in the lanterns. Then the LED and power wiring were soldered directly to them. After which I painted flat black. They look exactly like ropes. BTW, I ran 6-32 hardened all thread rods through the bottom of the hull and drilled out the mounting posts so they can slip over the rods. The front post is now used for +12 volts and the back post is ground. Inside the hull are individual resistors mounted on a hand made P C Board for running power to each individual LED. There are 15 LED's in all they each have built in flickering circuitry so they flicker independently. Very realistic looking in a darkened room. No visible wiring and the threaded rod makes the mounting of the ship to the base incredibly strong and secure. No worries about that breaking loose. The threaded rods are actually wood glued into the drilled holes. The bottom nuts are just there so I don't lose them. The tricky part was drilling the 1/8" holes in the 6mm wood keel. There's only a 1/32" of an inch left on either side. No room for error there.
Beautiful work John. Absolutely stunning Spence
Quality work there John, very well done she really is looking fab.... Regards Alan
Just a little bit of an update. Got these finished today. They are modeled after the movie version (of course).
Loving this build, it does look fantastic. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Top work there sir Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Just a small update on the shrouds, etc. I just have to finish lashing the stiffeners in the other 5 locations. Making your own rope is definitely the ticket.
Looks absolutely bang on, good job
Jase“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Hello Johncal, Excellent work keep sending in pictures love the detail great job. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Excellent build as usual Johncal, attention to detail is great, you must have watched he film 20 times now  . Keep up the great work. Peter. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Hi This looks fantastic, really nice. How did you get the shroud thread to look like this? Is it painted or waxed in some way? Steve
I use an outdoor polyester thread which has a sheen to it. Other that winding it on the rope walk there is nothing else that needs to be done. It is a bit touchy to work with because its slippery, but theres no fuzz so no waxing necessary. Its just that every knot MUST have a drop of C A glue or it will unknot.
Onthe plus side it is instantly ready to use once wound and it is virtually unbreakabke. It is massively strong. I touch up all the glued knots with flat black paint to give it that tarred look.
petpole wrote:Excellent build as usual Johncal, attention to detail is great, you must have watched he film 20 times now  . Keep up the great work. Peter. I would say thats actually about right. Also tons of internet photos and tons of research books.
Nice work John
Looks absolutely perfect, I love the droop in the ratlines too, very realistic. Steve
stevie_o wrote:Looks absolutely perfect, I love the droop in the ratlines too, very realistic. Steve That's the advantage to winding your own rope, especially if you use the right kind of thread. It responds much more naturally and realistically! Thanks so much for your kind words.
Beautiful work and have to say am very impressed with the rope work... Will be giving that some thought for my builds....  all credit to you... Regards Alan
