The 50 litres is a referal to the engine size or cylinder capacity. New money Karl!!!
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Pratt & Whitney 50 litre 18 cylinder Radial Airplane Engine,from what I can surmise it was basically 2 radial engines bolted together  it had a power output of 2000hp & was fitted to the F4U Corsair dive bomber & gave it it's nickname of Whistling Death Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
 Another question not answered So here is a new one The first MK1 Spitfires where delivered in what year and to what squadron and also the serial numbers of the first two aircraft Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro Groups: Registered
Joined: 05/12/2012 Posts: 258 Points: 754 Location: manchester
first mk1 spitfires were k9781 and 9782 to 19 squadran duxford in 1938
 Hi Benny correct over to you Sir Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
ok try this one which heavy night bomber entered service with 38 squadron in November 1936 only to be replaced by the new wellington in july 1939 benny b.
Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
The Fairey Hendon Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
correct your turn bob
Which heavy metal frontman is also a certified airline pilot, and also which group does he front? Regards Bob Builds in progress
kwakermad wrote:Which heavy metal frontman is also a certified airline pilot, and also which group does he front? Bruce Dickinson front man of the mighty Iron maiden “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Spot on Jase, even if you had to frig the spelling to get it answered Over to you Regards Bob Builds in progress
ok
The hanger in which the Spruce Goose was built has more recently been used as a set in a film.
Name the film (full name not just the first two words) oops is that a clue? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Star Trek "into Darkness"
Spot on
Over to you “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
What aircraft was designated "Navy One" and why did it have its place in history...
Lockheed S-3 Viking,carried George Bush to the USS Abraham Lincoln where he gave the "Mission Accomplished" speech ending the US involvement in Iraq in 2003 Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Correct Rob  over to you!
Sorry folks,had no idea that this was still open,as website not flagged up the new post when it went up. An easy one.....who were the Tuskegee Airmen? Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
they were the African/American pilots of ww2 known as red tails that to easy rob
