Hi fox. Fantastic looking build. Keep up the good work Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Foz, very nice looking build you have there, think she will turn out to be a build you can be very proud of....  .. Very well done... Regards Alan
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Looking excellent Foz. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
 Looking good Foz nice build rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Thanks for all the nice comments lads, really appreciated. Well have done the first foremast yard but as the plans and the magazine pictures are not to cleaver not sure if i have everything done or in the right place.   That's it for now and back to work tomorrow so time to leave the build for a few days.
Have a quick question. On the yards you have to make a sling type thing using black beads to hold the yard to the mast.
The ones supplied are all different sizes, does anyone know what these are called as i want to get some that are all the same size.
Foz
Joined: 02/09/2012 Posts: 73 Points: 225 Location: York
I think they are called Parral Beads Foz. There are different shaped ones to go on the levers of the falconets, but I am going to buy some different falconets which are smaller and more in scale, so wont be using the ones supplied. I sorted the beads to separate the two types, although there are still some slight differences, but they look fine when fitted! Currently Building:
Eaglemoss HMB Endeavour De Agostini Sovereign of the Seas
Thanks for that Gus. I found some at CMB so brought enough for all the masts. So a quick update as i am up to part 87. First off is the main mast, well the start of it, have not stuck anything together yet just put in place to see what it looks like.  Think is going to be quite big and no idea were i will put her.
Also i have added the supports for the ships boat and the first anchor.   Well that's it for now. As always comments most welcome. Regards Foz
Made a start today on the ships boat, hopefully will get it finished today.  If i could ask Karl were he got the anchor and barrels from that he added to his as that makes it look really neat, as he said in his build it is lacking the fine detail. Regards Foz
Finally found the time to get the ships boat finished.    Well that's it for now and back to the masts. Regards Foz
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Very nice build Fozy. Ilike this one a lot HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Thanks for the nice comment moriarty. much appreciated.
Foz
So have finished the ships boat now stating on the fore mast. Got the first spar on but making the yard sling took me an hour.
After that was done got the first spar in place on the fore mast.   Well that's it for now. As always comments most welcome. Regards Foz
Looking really good Foz, really like your build....  .. Keep up the great work... Regards Alan
Thanks Alan. Really appreciate the kind words.
So have added the other spars to the fore mast but not secured it i place yet.   Well that's it for today. As always comments always welcome. Regards Foz
Now started work on the main mast.
Really starting to take shape now.  Well that's it for now. Regards Foz
Guest (6)
