Hi cal. Very nice work. Look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looking Good Cal J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Spot on Cal, you are really cracking on with this build Steve
Great work cal, love the tiling.
hi cal, starting to look the biz,well done. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Cal, coming along very nicely indeed... Regards Alan
 Rank: Pro  Groups: Registered
Joined: 24/01/2011 Posts: 206 Points: 614 Location: halifax
Issue 83 finally finished ...going to have to redo the chainwales ftom issue 75 due to using 4mm wood instead of 5mm when I made the dead eyes cal attached the following image(s):
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
cal wrote:Issue 83 finally finished ...going to have to redo the chainwales ftom issue 75 due to using 4mm wood instead of 5mm when I made the dead eyes These things are sent to try us Cal, keep up the good work. Regards Alan England expects that every man will do his duty.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Sorry to here about little mishap.
Very nice work though, keep up the good work.
Foz
Some nice work there Cal, bad luck about the chainwales but we have all done things that need to be redone and it never takes as long second time round Steve
Looking good there Cal, am sure you will get the chainwale problem sorted in no time at all.... Regards Alan
Looking good there Cal. Smile in the face of adversity. I do believe we all have done something similar. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Next set of pictures are up to issue 87 only attached one side of wales due to having to remake the main and mizzen mast ones cal attached the following image(s):
Very nice Cal, really looking good Steve
Beautiful Cal, those decks look gorgeous.
Some really nice work going on there Cal, think you are going to end up with a beautiful build..... Keep posting those pics for us.....
coming on a treat cal, well done m8. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Looking good
J“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
thanks everyone the comments mean a lot
Never thought id get this far but here's up to issue 90 cal attached the following image(s):
