Hi All, Found this Micro-Mesh craft kit on ebay. It can be used on all sorts of materials and has a wide range of grit sizes in one kit. Contents: 9 double sided pads 3 double sided finger files - giving six grades 1 bottle micro liquid + cloth     Hope you find this useful. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
thanks for the pics del. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks Del for the good info  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Might have to invest in one Thanks for sharing J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
def get those. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Guys, Glad I could help out. The pads are only 2 inches square, but they are double sided and they reckon they last 20 times longer than other items for the same job. There are other sellers on ebay that do larger pieces should you require them when replacements are needed. I thought this was a good starter so you can see how it works. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
do you think the pads can be easily cut down into narrow fingers for detail work? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
jase wrote:do you think the pads can be easily cut down into narrow fingers for detail work? Hi Jase, The pads as I mentioned are only 2 inches square but the centre is of a foam construction with a thin abrasive layer either side, therefore I don`t see any reason why you should not be able to cut them if required. The finger files supplied give you 6 of the 9 grades in the selection of pads. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
