8 Pages <12345>»
Moebius 1/32 Flying Sub Diary Options
claret
#41 Posted : 06 October 2013 19:40:41
Hi,
I have sprayed the bulkhead section Tamiya Matt Dark Sea Grey and let to dry. The back of the speaker was painted matt black and the speaker mesh Tamiya Matt Aluminium. Also drilled out the recesses on three 'eye' shaped buttons, to put thin wire in to act as toggle switches.
I am going to give it a dark wash to high the mouldings, but have never attempted this before, and will start to put the decals on the instrument panel.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#42 Posted : 06 October 2013 20:29:17
Looking great its the little details that bring it to life.
J
#43 Posted : 06 October 2013 21:16:34
#44 Posted : 06 October 2013 23:28:22
Some excellent fine detailed work there Claret, think you are doing a fabulous job on her... Cool Cool . Love looking in on this build so keep posting.... Cool Cool
claret
#45 Posted : 07 October 2013 09:02:20
Hi Jase, Steve & Alan,
Thanks for looking in and commenting.
I am enjoying the build, as a break from the SOTS when I am waiting for paint or glue to dry.
I am also getting the hang of painting with an airbrush.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#46 Posted : 07 October 2013 13:48:19
Hi All,
A bit more progress, fixing the ladder stowage bracket in place. PE bracket cut from sheet and burrs filed off.
It was bent into shape, cleaned with nail varnish remover and superglued into position ready for priming.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#47 Posted : 07 October 2013 13:53:25
Is the etch in with the kit or your detail? if you want a cheper alternative to cleaning your etch try white vinigar
comming together well
J
claret
#48 Posted : 07 October 2013 13:59:07
Hi All,
Thought I would tackle the bulkhead that has the bunk bed and cupboards.
There are PE cupboard handles, but it is recommended that the plastic behind is drilled out to give a bit of depth to the handle.
The moulded handles were cut of and sanded down with P1200 wet and dry.
Also, the moulding is inaccurate compared with the screen shots. The two middle cupboard doors are not there, so I decided to remove them. I gently cut away with a sharp scalpel until they fell out. I handed all the edges with fine sand paper, but will now have to use plastic sheet to box the storage area in later. I also scored around the remaining cupboards and draws to give a little more depth to the gaps.
Progress so far:
I then sprayed the part with grey primer.
Thats all for now. Thanks for looking.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Foz
#49 Posted : 07 October 2013 15:27:49
Really smart build there Claret. Love the detail you are going in to.
Foz
court orchard
#50 Posted : 07 October 2013 19:57:41
Cracking build, lovely detail workThumpUp
#51 Posted : 07 October 2013 22:55:17
Looks better every time I look in.... Great job you are doing Claret....Cool Cool
claret
#52 Posted : 08 October 2013 08:28:51
Hi Foz, Andy & Alan,
Thanks for looking in and the comments.
Never having used PE Before, I am amazed at how much detail can be added.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#53 Posted : 08 October 2013 08:46:24
BigGrin Wow this build is stunning . Well done Claret rgd Martyn BigGrin
#54 Posted : 08 October 2013 11:20:34
Hi Claret you are really making a good job of this interesting modelBigGrin Kind regards Mike
#55 Posted : 08 October 2013 17:43:58
I really like this kit,it's so unusual. nice job too.
claret
#56 Posted : 09 October 2013 08:47:34
Hi Martyn, Mike & Karl,
Thanks for looking in and your kind comments.
I am glad you are enjoying the diary. I am certainly enjoying building it.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#57 Posted : 10 October 2013 08:38:41
Hi All,
Finally used one of the decals. I cut the grill mesh parts out as I thought the PE was more realistic. Although the decal set is the one for the PE. I have found that because of the raised areas on the PE, there is some creasing. This is only noticeable at certain angles and hopefully will be invisiable once enclosed. I will give the decal a coat of matt clear which should help.
Thats all for now.
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#58 Posted : 10 October 2013 17:43:15
Wonderfull clean and neat work ClaretCool Cool I must confess to never watching the series,I was a 'Blake's 7' kid.You don't fancy building the 'Liberator' next do you?LOL LOL
Kind Regards Nigel
claret
#59 Posted : 10 October 2013 17:47:49
Hi Nigel,
Thanks for your nice comments.
Blake's 7, now that was a classic!!
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#60 Posted : 10 October 2013 17:48:02
BigGrin Hi Claret
have you tried Micro Sol and Micro Set on the decals as it can get decals to soften into the spaces, just a suggestion if you have already tried it sorry to teach you to suck eggs
8 Pages <12345>»
This page was generated in 0.238 seconds.
