Question to proffesionals Options
viperek
#1 Posted : 22 June 2010 17:40:35
Rank: Amateur level 2
Hi there i started building my Victory the other week and i found the glue supplied "not very strong" any odeas about alternatives ? Need something what drys quick and is very strong. Cheers guys
Capt Stedders
#2 Posted : 22 June 2010 17:43:35
What: Aliphatic resin
Where: http://www.cornwallmodel...catalog/wood_glues.html
Why: Fast tack, strong bond between wooden parts, sand-able.
Hope that helps.
Edit: The bond is quite fearsome when cured, so do dry-fit your parts first (and pay very close attention to the build instructions - some parts (such as the hull formers on the main ship) should not be glued to the keel until later.
Also, check that your build parts are unwarped before doing any gluing.
Schnellboots on back burner
Tools.
viperek
#3 Posted : 22 June 2010 17:46:04
Hope that helps.
Thanks for rapid response ! Will order it this week.
Horatio's Eyepatch
#4 Posted : 22 June 2010 20:17:14
You may now sand this thread. BigGrin
doremi495
#5 Posted : 24 June 2010 01:49:00
I use Evostik white PVA. Dries solid and parts can be adjusted for about 10-20 mins after glueing.
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
benny
#6 Posted : 24 June 2010 22:30:21
hi i use evostik too but if you realise you have made a mistake after it has dried just run the hot tap and place the glued area under the tap and wiggle it gently and it will come free..i did this after 5 weeks of it being glued and had no problem
cheers benny
