 Rank: Pro  Groups: Registered
Joined: 28/03/2010 Posts: 152 Points: 513 Location: Liverpool,England
Mike Turpin wrote:I would agree with Willie that you can bend the very thin planks between your thumb and finger (as per the launch link above) however I would recommend that you are very careful if you try to do it dry, because the fibres will tend to splinter when you get to the exteme curvature towards the bows. I personally would recommend that you at least moisten the plank when you try to bend it and apply the pressure gradually to get the sharper bends.
Mike T I have to agree with Mike on this. Whilst you can bend strakes dry between your thumb and forefinger dry, wetting them drastically lessens the risk of them fracturing. I'm not an expert model maker but I am a carpenter and understand the behaviours of wood fibres. Hardwoods have denser fibres and are much more likely to split or splinter. Jimmy L.
current builds : Lancaster 1/32 (Hachette) Revell USS Kearsarge Titanic Lifeboat
I started off with nothing and I've still got most of it left.
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
you dont bend them with your fingers your nail dose the bending
having done my launch (see first wooden ship build) i would have to say my top tip would be to split the planks in two lenghtways. they are easier to fit and shape “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
jase wrote:having done my launch (see first wooden ship build) i would have to say my top tip would be to split the planks in two lenghtways. they are easier to fit and shape Isn't that defeating the object? Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
Good morning shipmates..I tried splitting the planks but landed up with planks of slightly differing diameters...I now know where I went wrong on my launch planking, I am in the process of rectifying it... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 02/04/2010 Posts: 491 Points: 1,460 Location: Poole
jonny7england wrote:Good morning shipmates..I tried splitting the planks but landed up with planks of slightly differing diameters...I now know where I went wrong on my launch planking, I am in the process of rectifying it... I found that placing the plank that is to be split onto a length of double sided sticky tape before cutting helps stop it from shifting around when you start cutting it. Also, light strokes with your scalpel/craft knife, work better than trying to cut the wood in one pass. Schnellboots on back burner
Tools.
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
I always soften my planking when using such a narrow gauge as in the launch - I boil the water and then leave for ten minutes You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Joined: 08/05/2010 Posts: 236 Points: 808 Location: Manchester
My first attempt at planking will be on the weekend. ive read lots of good advice and will crack on with the launch then. After a good run up. I posted this to 'gee' myself up for the task.I need time for the courage to build up lol. my cannon is done with slight weathering on it to wheels, pleased with it. Everything is my first attempt tho. Saving my money for a camera at mo. And not started my carronade as yet. Smaller run up required tho. Dont think much of the free tool kit. But hey thats why its free eh! Went and bought my own drill, knife aand files from 'games workshop'. Happy building shipmates i dont know what weapons will be used in ww3 but ww4 will be sticks and stones.
thats the slots done
Hi willie! Great minds think alike. I to have the Unimat 1, but with 1000mm long Machine Bed good idea to use the milling option better than using needle files and your launch looks good.
flippin' ek,now I've seen it all, a milling machine to cut oarlock slots.you can make a mold to make the flippin' boat. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 27/03/2010 Posts: 188 Points: 614 Location: Llandudno
Want one of them NOW
Ouch!! More expense...Launch looks good though? Errr..think I'll stick to the good old fashioned do it by hand system... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
