 Rank: Pro  Groups: Registered
Joined: 30/04/2013 Posts: 105 Points: 301 Location: Perth
I know you get a full race body, but how does it work? Is it a whole model, front and rear wing included?
Or is it just the main body?
Just the main body as far as I'm aware... Front and rear wings are fine... From pictures the racing body has holes in the side to accommodate the engine but if your wanting to display it then I can imagine parts are left off to allow the display to be fitted.. Spencer
Issue 20 contains an exploded view plan of the entire model.
There is also a view that shows the parts which make up the Running Body (Racing), and another view which shows the parts that make up the Display body, along with Issue numbers of which parts are supplied where.
Thanks that confirms my suspicions...
Im gonna have to order a back up and spare issue one, for the front wing. As one prang ..... And it's wrecked.
Thanks
 Rank: Pro  Groups: Joined: 11/04/2013 Posts: 119 Points: 347
The front and rear wings that come in the first few issues are part of the display body. Issues 95,96,and 97 have the running body versions of the front and rear wings.
Awesome thanks rowdy.
That's exactly the answer I was looking for .
