Small scale brushes Options
petpole
#1 Posted : 01 October 2013 22:34:46
Hi all I do hope someone could help me, for years I have looked for good quality brushes for painting small detail and I have tried various types even citadel one (which I though rubbish, unless it was to 2 I got as the bristles came out), but some of the most excellent modellers on. The forum could suggest a good make for me to get and if possible where from.
Thanks for your help.
Peter
Confused Confused Confused Confused Confused
#2 Posted : 01 October 2013 22:39:55
you really are asking a very awkward question, with brushes it's more the aftercare and general looking after, and in this case you get what you pay for,I personally go for sable,don.t forget a good soapy wash after you have cleaned them.
#3 Posted : 01 October 2013 23:01:13
BigGrin Hi Petpole
Nothing awkward about buying brushes just go to your local artists store like Hobbystore for instance and buy the best you can afford , sable are generally the best and with all brushes be they the cheap ones or expensive ones some shedding of hairs will occur.
Its the cleaning of brushes that is the most important thing to get right as a badly cleaned brush will just clog up and fail quickly. I generally use liquid detergent with acrylics giving the brush a good spread so the cleaning solution fully penetrates the hairs and after a good rinse in clean water to remove the detergent. To make sure all the paint has gone i do this again and after use clean water to set the hairs back in position and then leave to dry naturally.
If the brush was supplied with a plastic tube cover always retain this and store the brush in it ,doing this should let you get a good few years service from a brush . hope this helps
court orchard
#4 Posted : 01 October 2013 23:27:37
Hi,
For small brushes I only use Red Kolinsky Sable, nothing else comes close to their pick up and release. For sizes under 3 and down to 10/0 they are relatively cheap, typically about £3-£4, but will last for years if cared for. Currently my favourite supplier is Creative Models, because I like the large triangular handles.
http://www.creativemodels.co.uk....html?page=2&sort=2a
NMBROOK
#5 Posted : 01 October 2013 23:37:42
A tip that I found works well is after cleaning,work a little hair conditioner into the bristles and then rinse thoroughly.This keeps the bristles as soft as when they were new and I have actually had brushes improve with the use of this process.
Kind Regards Nigel
#6 Posted : 01 October 2013 23:56:46
court orchard wrote:
Hi,
I agree with you on the triangular handels they are more comfertable and controlerble.
petpole
#7 Posted : 02 October 2013 00:08:38
Thanks for all the suggestions, I knew it was going to be a hard subject to answer.
As for cleaning my brushes, as I only use acrylics now days I generally wash them out in clean running cold water, dry them then use a shaving foam dish (the ones you get from wilkos ) with a little water just to get the softness back then another quick rinse in warm water and then wrap them in parchment paper with an elastic band tied round and left to dry on its own accord and also it keeps the shape better.
I know it's a long process but it does work.
Peter
BigGrin BigGrin BigGrin
Wilfy the Sea Dog
#8 Posted : 02 October 2013 07:31:47
Hi,
I always use Winsor & Newton Series 7 Miniature for fine detail painting. They are a little pricey but hold their point well & do last.
I clean them in the appropriate thinner for the paint I am using & then wash them in water after massaging in a little 'Brush cleaner & Preserver'
http://www.ebay.co.uk/it...amp;hash=item53fd49c63e
http://www.ebay.co.uk/it...amp;hash=item41591d6f5c
Hope that helps.
Wilfy
#9 Posted : 02 October 2013 09:45:57
You can use hair conditioner too on the bristles.. Keeps them nice and soft.. Remember to rinse through though
Spencer
#10 Posted : 02 October 2013 13:43:13
Hi,
Andy, are these the actual brushes you ordered or do you mean any brand of Kolinsky? Im just wondering as the ones in the link are creative models own brand and have in the past wondered how good they were at that price. I have been using Dahler Rowney Aquafines for a while as they are the only ones in my local shop but have had my eye on the set of small brushes at the link you posted.
court orchard
#11 Posted : 02 October 2013 15:48:57
Hi,
Hi Steve,
Any brand which uses Kolinsky Sable are OK. I ordered the Creative Model ones for my most recent ones, because they go down to very small sizes e.g. 10/0 and they have the chunky triangular handles, which are easier to hold. We used Kolinsky Brushes at work as they are considered the finest (in both senses).
For anyone who doesn't know the Kolinsky is a type of weasel (not a sable) that lives in siberia and grows particularly fine fur, because of the very cold temperatures. Only the hair from the tail is considered good enough and real aficionados say that only the male tail will do. Larger watercolour brushes can run into the hundreds of pounds!
petpole
#12 Posted : 02 October 2013 16:02:58
Thanks Andy just placed an order for a set of 4 not to expensive either, only £10.95 just have to wait for slow mail to come now.
Just wished they would hurry up with transporter tech so we get stuff within the hour.
LOL LOL LOL
Peter
arnoldbrame
#13 Posted : 14 October 2013 07:35:33
Hi,
Me too triangular handels are more comfertable.
This page was generated in 0.280 seconds.
