Hi, I have noticed on cornwall models that they now do the resistor head for the bender. If you happen to have a lecy plank bender would the head fit a normal soldering if(I have 2 Sizes soldering iron) . As its only £10 for the head it would be cheaper for me. Thanks..chris....plank bender head....On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 20/03/2010 Posts: 462 Points: 1,299 Location: Tortuga !
Thanks for that, Just ordered one along with a few other bits, Like you I will just put it on the end of my spare soldering iron, well cheaper than the £35+ !! Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
damn..muggins here paid £35 cheers benny
Joined: 18/03/2010 Posts: 55 Points: 135 Location: Lordswood, Chatham
Didn't want to start a new thread on this but can anyone suggest a place I can get a electric plank bender? Cornwall boats are out of stock and there are none on ebay....that's about as far as my shop wisdom goes...any help appreciated thanks!
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
try westbourne model centre
Or can I buy a soldering Iron and then buy the head as Magpie is questioning?
Eaglejay wrote:Or can I buy a soldering Iron and then buy the head as Magpie is questioning? Wanna save money then buy a solder iron from Ebay and the resistor head from Cornwall Models! I have a couple of old irons which still work so i will doctor one of those. As for the bending block which comes with the full kit, Simples, Scrap of wood about 4" (100mm) long, drill a 1" hole at one end and then then cut in half through the hole! then shape the other end to a nice long curve, Take a look at the picture (Lecky Plank Bender) you'll get the idea. Hope this helps! Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
magpie1832 wrote:Hi, I have noticed on cornwall models that they now do the resistor head for the bender. If you happen to have a lecy plank bender would the head fit a normal soldering if(I have 2 Sizes soldering iron) . As its only £10 for the head it would be cheaper for me. Thanks..chris....plank bender head.... Hi Magpie, DO NOT BUYthe resistor, its not the head but the heating element no head!!! mines just come!!! £10 wasted, GUTTED!!! Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
